Space & SciFi
Space & SciFi
Tulsa Modeler's Forum
  • Home
  • Contest
    • 2022 Contest Report
    • 2019 Contest Report
    • 2018 Contest Report
    • 2017 Contest Report
    • 2016 Contest Pictures
    • 2015 Contest Pictures
    • 2014 Contest Pictures
    • 2013 Contest Pictures
    • Other Contests
  • Gallery
    • Overview
    • Group Build, Vietnam
    • Group Build, MiG-21
    • Group Build, Wet Willy
    • Group Build, The Fifties
    • Brad Hair
    • Bruce Brotherton
    • Carl Halfpapp
    • Casey Gray
    • Court Hughes
    • Daniel Attillo
    • Dave Horn
    • Greg Kittinger
    • Kenny Gregory
    • Kurt Krans
    • Paul Wilsford
    • Wes Pringle
  • Resources
    • General
    • Catalogues
    • Research
    • IPMS Newsletters
    • Fonts for Modeling
  • Contact
  • About
  • Forum
  • Exec
  • More
    Use tab to navigate through the menu items.
    To see this working, head to your live site.
    • Categories
    • All Posts
    • My Posts
    Paul Wilsford
    Feb 13, 2018
    Pro Modeler He 111 P
    in On the Bench
    I have had this one going for a couple of months now. I had started one before but because I didn't have room and /or the right colors I never finished it so I gave it to Allan. Kurt convinced me that I should give one another try so I purchased this on off of eBay. It came with an Eduard zoom interior set which I only used the seat belts. The pit interior seemed to go together with out much fuss. I thin finished the interior of the main part of the fuselage.
    10 comments
    0
    Paul Wilsford
    Feb 13, 2018
    0
    Paul Wilsford
    Feb 13, 2018
    0
    Paul Wilsford
    Feb 13, 2018
    I sprayed the cockpit with RLM 66 and the radio / passenger compartment I used RLM 02. even though th3 insides will not be seen or exposed except through a small opening through the upper gun position. The tail wheel assembly did prove a bit fiddly and the bulkheads made it difficult to close up the fuselage sides.. I had assembled the center part of the wing and engine nacelles and it snapped right onto the fuselage with minor gaps in the wing to fuse joins.
    0
    Paul Wilsford
    Feb 13, 2018
    0
    Paul Wilsford
    Feb 13, 2018
    0
    Paul Wilsford
    Feb 13, 2018  ·  Edited: Feb 13, 2018
    Prior to getting all the parts together I decided too shoot the RLM 76 undersides then put in the windows for the gondola. This kit also has some transparencies that belong to the H-3 variation and they are so closely numbered as to being identical so you have to keep a close look out. The fit of the fuse sides were a bit frustrating because one side was warped ever so slightly . I use the heat from a hair dryer to massage it a bit and with a bit of convincing it came together finally.
    The nacelles them selves were another fiddly feature of this kit as they consist of 9 or 12 pieces with no positive mounting features. Only a beveled side to mate the surfaces to each other. This kind of smacks limited run to me but all-in-all this time they went together with out much fuss.
    Finally I got to get to the transparencies. The one that always gets me frustrated the most is the nose gun blister. I bit the bullet and ordered the Eduard masks and spent the better part of a whole day masking all of the clear bits.. I also used Micro Ind. Micro Mask, the blue stuff, for that nose piece and it seemed to work the charm I'll find out after painting how well it worked.
