Space & SciFi
Space & SciFi
Tulsa Modeler's Forum
  • Home
  • Contest
    • 2022 Contest Report
    • 2019 Contest Report
    • 2018 Contest Report
    • 2017 Contest Report
    • 2016 Contest Pictures
    • 2015 Contest Pictures
    • 2014 Contest Pictures
    • 2013 Contest Pictures
    • Other Contests
  • Gallery
    • Overview
    • Group Build, Vietnam
    • Group Build, MiG-21
    • Group Build, Wet Willy
    • Group Build, The Fifties
    • Brad Hair
    • Bruce Brotherton
    • Carl Halfpapp
    • Casey Gray
    • Court Hughes
    • Daniel Attillo
    • Dave Horn
    • Greg Kittinger
    • Kenny Gregory
    • Kurt Krans
    • Paul Wilsford
    • Wes Pringle
  • Resources
    • General
    • Catalogues
    • Research
    • IPMS Newsletters
    • Fonts for Modeling
  • Contact
  • About
  • Forum
  • Exec
  • More
    Use tab to navigate through the menu items.
    To see this working, head to your live site.
    • Categories
    • All Posts
    • My Posts
    greg.kittinger
    Apr 06, 2017
    1/72 SBD for Midway Group build
    in On the Bench
    I pulled a Hasegawa SBD-3 out of my stash for a group build on iModeler, to celebrate the anniversary of Midway. I was originally intending OOB build, except I intended to drill out the holes in the flaps/dive brakes to make them more realistic. The way the wing sections are designed, they are molded as both upper and lower sections into the upper section of the wing.
    As I started drilling, I decided "hey! why not flatten this thick piece down, cut it out, then manufacture the lower section from styrene and present the flaps and dive brakes open. If I had done some research first, I'd have found all this lovely detail:
    Whoops! Too late - I had already cut out the flaps! (well - I guess I could have glued them back shut, but I really thought they would look good open).
    So, I cut out the styrene lower brakes, and then drilled out all five sections (including the central lower brake section). Next came ribs and runners and spacers to represent the interior side of the flaps.
    Next, I have to even up the upper/lower wing join and blank it out with styrene, so I can drill it back open as research indicates, then create all the actuator elements. I'll also need to do some work on the underside of the wing/fuselage of the middle brake section once I've got the wings and fuselage together.
    More to come...
    10 comments
    0
    dhorn
    Apr 07, 2017
    Looking great! Don't go blind
    0
    greg.kittinger
    Apr 12, 2017  ·  Edited: Apr 12, 2017
    Some work on the interior - there was no detail, and I'm going to cut open the back sections of the canopy and mount them nested, so added ribbing and details to the back section sidewalls, some to the floor/cockpit area, and some to the upper sections of the front sidewall panels.
    0
    Paul Wilsford
    Apr 14, 2017
    Looking real good there
    0
    greg.kittinger
    Apr 17, 2017
    Some more work on the actuator area for the brakes and flaps - blanked off the section left by the gap of cutting off the original brake, drilled it out per reference photos, then built up the actuator control rods and brackets using styrene square strip and rods.
