Space & SciFi
Space & SciFi
Tulsa Modeler's Forum
  • Home
  • Contest
    • 2022 Contest Report
    • 2019 Contest Report
    • 2018 Contest Report
    • 2017 Contest Report
    • 2016 Contest Pictures
    • 2015 Contest Pictures
    • 2014 Contest Pictures
    • 2013 Contest Pictures
    • Other Contests
  • Gallery
    • Overview
    • Group Build, Vietnam
    • Group Build, MiG-21
    • Group Build, Wet Willy
    • Group Build, The Fifties
    • Brad Hair
    • Bruce Brotherton
    • Carl Halfpapp
    • Casey Gray
    • Court Hughes
    • Daniel Attillo
    • Dave Horn
    • Greg Kittinger
    • Kenny Gregory
    • Kurt Krans
    • Paul Wilsford
    • Wes Pringle
  • Resources
    • General
    • Catalogues
    • Research
    • IPMS Newsletters
    • Fonts for Modeling
  • Contact
  • About
  • Forum
  • Exec
  • More
    Use tab to navigate through the menu items.
    To see this working, head to your live site.
    • Categories
    • All Posts
    • My Posts
    Peter Zalesak
    Jul 20, 2020
    Dragon Sd.Kfz 251/1 ausf.C Schützenpanzerwagen
    in Corona Group Build
    So it turns out I like having a build going as I slowly get around to finishing previous builds. I dug around my stash and settled on this.
    The other thing I noticed is that our Corona Build participation has gone way down (last post was May 18?), so I figured I had better do my bit to get it going again. I don't know about you, but between the heat dome and the continuing Covid disaster unfolding, I'm not goin' out much.
    So at this point I've done about 80% of the assembly, and it's going pretty trouble-free. I have to give a shout-out at this point to Kurt for his recommendation of the Meng tweezers — I haven't twanged any parts across the room since I started using them — and to Dave for recommending liquid mask to temporarily afix road wheels.
    Here are the general progress shots...
    So as I said, this all went together beautifully. Then came the tracks. Individual links that hooded together and were capped with the "rubber pad" to hold the tracks together. I fiddled with forceps to try to keep the tracks together while gluing down the pad and it was an exercise in frustration. I have a pile of basswood blocks (stick stamps actually) of various sizes so I quickly glued together a small jig and thing started to go swimmingly, once I figured out that the rubber block had a orientation that you had to respect. the tracks are kind of flexible, depending on how far the glue ran — I got better as I went along.
    Almost ready for initial painting.
    0 comments
    0
    0 comments
